LED Turn signals require LED compatible flasher units, the normal flashers rely of current to heat a thermal switch AKA a bi-metallic strip to make & break contact... LED's draw significantly less power so the lights never flash... Also LED are polarity specific and usually on a Mopar the hazard flashers wires at the flasher need to be reversed.... Headlights should just be a drop in deal...Is there any special modifications required to get the LED lights to work with our cars? I seem to recall when LED headlights first came out that some additional wiring upgrades were required.
