Manifolds or headers?
FrnkNsteen
11:38 PM
Indiana
Quick question for you guys. I am getting ready to drop off my motor (440) at the machine shop to start getting it rebuilt for my Charger. I don't know what the exact internals will be yet. We will talk about that when I bring it there. His recommendation was a good set of forged pistons that will put us at around 9.25CR. Beyond that, we haven't talked specifics yet.
My plan is that I just want a good low range torque motor for the street. I don't race, but like to get on it from time to time, so I want something that will perform well in that 1500 - 5000 rpm range. I want to maintain a decent amount of vacuum to run the headlights, AC controls, etc. Plus, I'm planning to put the factory AC back in the car.
I am converting it to 4spd, and don't want to have to mess with header and clutch linkage interference like I did on my 4spd Cuda (400 4spd). I have a couple sets of HP manifolds, so I was thinking of going with them over headers.
Not to mention, with all the other costs of rebuilding the car, it wouldn't hurt my feelings to avoid the extra cost of headers, custom Z-bars, or hydraulic clutches!!
My question is this,... Can I get away with using the HP manifolds and still get good low end torque for the street. I know,.... everyone says manifolds don't flow as well, but I'm not building a hi-rpm race car. I just want something with some good grunt out of the hole.
If so, ... Can someone recommend a good cam to go with this type of setup. I talked briefly to the engine guy. He's an old school engine builder around here with a great reputation. I will see what he recommends, but would also appreciate opinions from here to see how they match up.
Please let me know your thoughts.
Thanks!
Unless you are building a 600+ HP engine, the HP manifolds on a street car only will do the job. I am a fan of the "Thumper" cams from Comp.Good sounding and work well on a street car. My 2 cents.
Thanks!
If your sticking with the OE intake, there's no reason to really go with headers because "flow in/flow out" from the chambers is not going to be that much different. I've used Voodoo cams by Lunati and I really like their performance. I do recommend if you buy this brand of cam, go with a kit that includes their lifters - they are matched in material for longevity. HP manifolds flow very well so I'd use them first to see what results you get and if you're satisfied. Installing headers presents a whole new set of expenses that you may not be able to justify in performance results.
Sounds like the manifolds would be fine for what your doing. You can always throw headers on it at a later date if you need more power.
I ran a summit 6401 cam (these lobes are available thru howards which would be a little more accurate than summits) with stock intake and exhaust manifolds. I was impressed with the low end and mid-range torque.
Thanks guys! Sounds like manifolds it is. I was thinking about going with an Edelbrock performer dual plane intake, but it sounds like it wouldn't gain me much if I am going with stock HP manifolds.
Am I correct in thinking that?
For stock intakes,... is there any difference in the standard 440s and the 440 HPs in regards to the intakes. I have a couple stock 440 intakes, but they are not off HP motors. Ok to use? or would I gain a little HP or Torque by going to the performer intake? I know this is the exhaust area,.... just trying to find the right package to go with the stock HP manifolds.
Oh,... one last thing. A little early for it, but what size exhaust works well with HP manifolds? I've heard going too big exhaust can lose torque. Would I go with a 2 1/4 or 2 1/2" pipes and super turbo style mufflers? Seems like bigger than that wouldn't help anything if running manifolds.
2 1/2 and use an H or X pipe
I got that header thing out of my system when I was 18 years old... Put the manifolds back when I was older and wiser at 26! Now at 55 I question what I was ever thinking to deal with the nonsense of burnt plug wires, leaking gaskets, etc. That and IMHO stock HP exhaust manifolds look nicer on a B body.
Interestingly enough,.... I was doing some readings on the advantages of adding an H or X pipe....
Pretty much everyone agrees that you can see some gain by adding a crossover pipe. Most agree that an H pipe helps more in lower RPM ranges and an X pipe helps more in upper RPM ranges.
What was interesting though, was a test that Engine Masters ran on the dyno. They took a motor and ran it on the dyno with no crossover exhaust and Gibson straight through mufflers. They then added an H pipe to the exhaust, while keeping everything else the same, including the length of the pipes and location of the mufflers, and ran it on the dyno again. Then they changed the crossover to an X pipe and repeated it. They ran each configuration 3 times and averaged the data from each run.
What they found was the H pipe added to the HP and torque curve up to about 4500 RPM, while the X Pipe mostly improved HP/torque in the upper part of the RPM range Proved what others have said. That being said,... the increases in torque/HP were only about 1.5 - 2 points though for a street car (might notice a difference in drag times though). They DID say the biggest thing they noticed was the sound. They said the X pipe sounded the best and was quieter at idle.
Hard to say if a person could even feel a 1.5 - 2 point difference in the seat of the pants, and if it is even worth the extra money to have either installed.
Link:
Link:
Interesting, thanks for posting
Thanks guys. I think I will go with the HP Manifolds on this car, as this will be our cruiser, get on it for fun, car. I've got the Cuda to play with if I want to start playing with building more performance. It has the 400 in it with Schumacher Tri-y headers and the Magnaflow exhaust.
I'm with you Dadsbee,... I'm 51 now and don't feel the need to mess with everything the headers can cause on both cars. You make a good point!
if you go headers , have them ceramic coated, and you need to keep tightening those bolts the first weeks . or you blow gaskets .
have found
good luck
I've been running tti headers for years without any kind of issue. I've used cast manifolds for years with no issue. I don't understand why people have exhaust problems.
I put hp manifolds on my newly built rb. The lunati cam i chose (10230703) says it should be used with headers on their spec, but i used manifolds anyway. They seem to build up too much heat, although probably my imagination. They seem to have a different tone than headers usually do, but I'm half deaf these days so who knows!
One problem i found is that the passenger side is very close to the rocker cover and made it impossible to switch to aluminum rocker covers. I will likely replace them with headers soon.
Exactly!
Headers. Less weight, cooler if ceramic. Underhood temps are 100 degrees cooler than stock confirmed by the laser temp gun. With an aluminum bell housing, tubular uca's and the TTI's, the squat actually changed. Every pound taken off these big girls is good. Carry the manifolds out to the shed and you will have your answer.
Wow.... I feel like a salmon swimming up-stream. HEADERS ALL DAY LONG. I've run Heddman, big tube Heddman & big tube Hooker & never had a z-bar issue or clearance problem of any type. Changing starters is an issue, but that's it. I haven't run stock style manifolds in over 30yrs and probably never will again. I have however switched to stock-style mufflers and don't run cherry bombs any more.
