Sportfury63
I have a 63 Plymouth Sport Fury with the 383 and factory Air. The ac compressor froze and burnt up, and I lost the belts too. I found this post from some time in the past that addresses my problem, and I need to get a "matched pair" of belts for this car. I currently have a have a pair of belts that are slightly different in length, and the longer belt is "sloppy". (found in the forum from a previous post--"A lot of people also don't know this, but you NEED to have what's called a "matched pair" of belts for the alternator and A/C. That means they were both cut from the same slab of belt material and probably sequential, so they are exactly the same length. This is NOT unimportant. Most big box "counter people" will give you a dumbfounded look when you ask for a matched pair of belts so you need to find a seasoned PARTS MAN. He will know"). Can anyone direct me to any supplier than can help me? Thanks SPORT FURY63
