Mean Green the Time Machine
I’m running a 4.10 gear and the converter is NOS Hurst 11” shotgun street converter that is a 19 spline ,I still have the original 66 transmission in the car so it’s tuff to find a performance converter but it’s stall is 2800 . The car is a slug out of the hole so I have work to do the carb for sure needs attention it’s a 12 second car .
Got it. I'm running the same gear ratio. I went with an FTI converter, 3600 stall.
I'm sure your right about the 12 sec, just a matter of finding it, but that's half the fun.
Give me a heads up the next time you head down to Mid Mi Motorplex, I'll try to make a run over and watch.
Been fighting with this carb ,I’m about ready to put the original one on :/
I highly recommend the edelbrock avs2. I was fighting factory carbs on my car, plopped one on, did a little tinkering, and it worked awesome!
Thank you the color combination is what drew me to this car , thanks for sharing the memories .
Update I got the carb stumbling problem fixed and went to test and the tack took a crap:/ it’s only 45 years old . Not sure what rpm were I was shifting at and very bad air but if did run 13.2 and 60 foot picked up but mile per hour was down 2 miles due to air and not shifting at 6000 ,but the carb stumbling is fixed sweeet…..
Yesterday we were at the Gladwin Airport drags and meals on wheels benefit food drive .
