Minnesota Gold
Just got my replacement bench seats, and they are terrific
Got my floor pan, driver side in too today. That’ll be fun
Passenger floor pan is 95% good. Wire wheel did a nice job on the rust to bare metal. Added some primer and looking to repair the 5%. I did pop the body plugs later.....added them back to avoid hitting the floor with drips.Left the buddy seat in there so my old *** had a place to hang out....
Got the block, heads, crank and rods off to the machinist today. Totally juiced. Going to get the heart and soul back into this metal monster soon.....she hasn’t made a sound since 79’
First patch done. I’m kind of a newbie at sheet metal, but am picking it up quick. I’m super juiced that the Evercoat went on so well and sanded. I got just about all I needed from this site as usual and the tips made a clean job of it.
42CC76A9-510A-4343-8749-3FDB19039E1F.jpeg 3C34556B-551A-469C-96EE-B4424F64B347.jpeg 987C389B-90DA-4029-AB74-7E9DD9F5EB53.jpeg
.....obviously a second coat will be needed , but it’s a solid repair
Going to tackle the back two quarters and trunk extensions next week. I’m sure that will be quite the challenge
Well, just went out and got a couple of gallons of ZZ-1 Gold Poly and supplies. I'm getting much closer to paint on the engine bay, trunk and other bits. Going to practice a bit first and try not to waste much paint.....but I've watched a million hrs of vids on the subject and will begin this process on areas I can re-paint as I mess up. Getting a middle of the road DeVilbiss set up, and will make sure I have a gun for primer only. Going to 600 grit the these areas, fix any pits and chips.....then hit it.
start on the hood...
...or go get a junkyard hood to practice on.
I happened to find a cavalier hood in my dumpster one day, so I pulled it knowing I'd need to practice on something before I painted my engine compartment.
It took three tries with scuffs/sanding in between before I felt comfortable trying it for real.
Orange peel was my worst issue.
"Too far" crust was the next biggest issue.
The Nason's paint I was using was somewhat prone to that so I had to take that into consideration.
Looking forward to seeing that car all shiny.
Well, I am going to definitely do that sir
Booster is off, and on its way to Booster Dewey.
Carb rebuilt , working on small part cleaning and restoration. Going to score some Easy Off for the super greasy stuff
1147BAD0-7A79-4EDE-B061-96A3FE37A73B.jpeg 15537D8E-8132-4B33-82DB-121EB61D304A.jpeg 41150C7F-336A-4E06-BBFA-B1C9A9AF8126.jpeg
I’ll add a wheel pic as well. Took one off the RIM and the inner was in great shape.....so I just sanded, primed and painted the outer. Used the yellow tape and cut out all the needed bits . Time consuming, but great results. I’m using a new Rustoleum product for exterior automotive trim and it’s great so far
Tail panel was fun . Cleaned with soap and water. Little acetone for grease and to remove loose paint. It turned out great.
39E7AC69-E283-4471-BD5F-7B7014D8365A.jpeg EFE62E83-3542-4AE8-9CFE-FA10F7E99EB7.jpeg 3B058AA2-7361-449F-94CB-B82CF9AB3EAD.jpeg FD81E33E-FA44-42CD-A0CE-D082E3BA16D0.jpeg D1FF6060-AE86-440E-BA2A-E098D7AFE050.jpeg
Super juiced the windshield came out and there was zero rust in there. Good day for sure.
227BE99D-3901-40F5-AE70-79A47C509660.jpeg 911502ED-E249-4C64-B202-4143E5E8E603.jpeg
