Modern Bullitt build
This car, when done, should go to SEMA or some other nationally recognized show. I think it would do incredibly well. It is an amazing build!
Fuel tank along with supply and return fuel lines are install!
Only 1 spot for a temperature sender on this gen3 Hemi, and I need two, 1 for the fuel injection and 1 for the gauge. I had to remove a freeze plug and make a plate that I could drill for an additional temperature sender.
I also have all of the wiring set and ready to enter and pass through the firewall through a split grommet. This will allow all of the plug-in connectors to pass through a single 2 1/4” hole hidden just above the transmission.
Thanks
Pat
Everything executed on this car is absolutely impeccable!
The only problem you will have is that you won't be able to lose something like 7 hubcaps during a car chase!!! :rofl:
The thermostat housing can be drilled/tapped, weld a bung into the radiator tank but your idea should work just fine.
Your attention to detail and flawless execution is unparalleled Pat!! This thing will be a trophy winner everywhere! Hopefully you have plans to show it off after it’s finished.
