What is the brand on that clamp and how does it hold when you shortened clamping area
It is looking dam fine
Excellent work! When I was younger I worked at an exhaust shop and really liked it, I was a bit of an "artist" in that I took a lot of time to get pipes to run well front to back. Since I no longer have an exhaust bender (despite lusting for one for years), I have taken to the same method you are using and have achieved some fantastic results that even a bender could not do. Most recently I snaked 2.5" exhaust through the 4 link system on my Cuda and it came out very well.
Thank You!
Pat
The right side was a little more work but turned out nice.
Next project is the trunk floor and mini tubs.
Thanks!
Pat
First off, your build is incredible. I’m late to the party, but it was awesome to be able to see it come together. How do you blend those patches so well, if I may ask? I noticed some weld seams are on 90 degree angles rather than just flat spots, and it all looks perfect once you’re done. Progressively finer sanding?
Pat
You do amazing work, it is a pleasure watching this car come together. Looking forward to seeing this and the Mustang side by side
Thank you sir!Really exceptional work !
