It's the front frame, that needs to be checked. Never considered it could be bent.
I check mine, by putting same height jack stands, level floor, the stands at the frame rails behind the front wheel wells. There, the car's frame should be sitting fairly even, side to side. The K member uses four bolts, to fasten it to the frame...measure from each bolt head, to the floor. Your just looking for difference, side to side, not all four being the same, since the car is at an angle. Also measure both front frame rails, forward of the K member, at same locations.
If it's twisted, the measurements will tell you.
I did measure this morning actually
So I'm pretty convinced that we're ok frame-wise everything was less than 1/8" difference between sides, at the k frame attachments, rad support , and also side to side at the rear
I actually set the car on four stands, I still wasn't sure about the effect on side to side lean of the new rear hd leaf springs
I also swapped the rear leaves left and right, just to be certain there was no effect on the front
So then after speaking with the guys at firm feel (who were somewhat helpful) I did swap the bars from left to right as apparently they are the same, and are "point to flat" when laying on flat bench, one end is on flat, the other end is pointed straight up and this has no effect
I have narrowed the issue to the adjuster blade being 3/8-1/2" further up in the control arm with no bolt installed (just pushed up by hand to remove "slack") on the left side vs the right This is the clearance I need to keep the blade from bottoming on the frame rail on hard right turns (this is about the difference between the two blade to frame clearances when car is level at ride height)
So with the new torsion bar crossmember and the lower control arm being possible root causes (because the torsion bar swap between these and .089"'s and also between these .096"'s swapped left to right), I figured maybe control arm ? socket wear ? (pivot bushings are new)
So I borrowed an e body lh control arm, and swapped it in, still the adjuster blade sits 1/2" further up in the control arm BEFORE loading or even installing the bolt, just the freeplay
So I reopened the WTB for the lh lca, perhaps the borrowed one I have has wear also
Also, the hexes are similar in orientation , when flat is at bottom, the bottom of the "finger" is about lined up with the top of the adjuster block window
Maybe I can get a control arm with less wear ?
Or it still could be the new torsion crossmember sockets, but that seems much less likely
Anyway, I may need to retitle this thread or open a new one, because this issue really seems to be about "torsion bar adjuster blade slack/play"
Or I can try to get some feedback from anyone that has torsion bars installed but not "loaded" to see how far up into the control arm , and what the difference is between sides ?
Thanks for any input and ideas.....hopefully I will solve this....this thing needs to be driven !
