- 10:39 AM
- Apr 13, 2012
- Granite Bay CA
This is true.Being a Motorhome motor, you can be guaranteed sure that it's never been revved anywhere near redline, had foot on the floor neutral drops done to the tranny, and other abuses that big blocks get! And they don't have many miles on them to begin with. Good Luck
MH engines often came with double roller timing chains and windage trays too.
Yeah, the compression ratios were low. A steel shim head gasket is already used on them so don't expect to gain anything there. The only fix is new pistons. Stock ones were often flat tops but they were almost .200" BELOW deck at TDC ! You can improve things with the
Edelbrock small chamber heads....
If you are doing a big block swap, the MH engine can get you in the game right now for little $$$. Later as you have more money you can pull the engine for a proper rebuild.
