This rotisserie is the best thing since sliced bread . . . been doing a lot of thinking and working on the bottom of the car . . .
After talking to Devin - decided that his idea of bed liner on the bottom of the car is a pretty good idea, so I ordered that this week . . .
And I've been working on the bottom of the car as well, trying to get some things wrapped up so that the car can go back on all fours . . .
Got this area cleaned up a bit, and in epoxy primer . . . the top right is where my E-brake cable will come from the cab . . .
An this is the tight area that I need to figure out the connection to the E-brakes . . .
Here's the bracket that will need to be mounted ( hope that I have enough room here to make it all happen . . . it's going to be tight . . .
Also working on the gas fill tube . . . this is bolted in place, and cut through the floor of the trunk . ..
from there I'm thinking going in this direction ( it will go through the frame rail . . .
and one more piece angled to bring it into the center section then a rubber hose connection to the tank . . .
These pieces will allow me to do some more practice on my TIG welding too . . .
Gawd . . . I'm hoping that this is going to work out for the tube
( if it's all welded in place - is that a problem - or does it need to rubber isolated ? )
		 I don't envy you lol. Not to rain on your parade but you've got one more hole to put in that floor, your A/C drain. O.K. that's just a small job project that can be done afterwards.
