My Name is Earl Weaver am A big mopar nut
Earl Weaver
New Member
4:25 PM
I have been in the a bodys for many years and now have bought me a 68 dodge cornet R/t and need to do a few things to fix on lights on the dash lights don't work and a few other things the speedo. is reading way to fast about 35 mph need to fix that.
I will post some pictures of the later once I get it figured out thanks for the member ship
Earl
Welcome to FBBO Earl :thumbsup:
Welcome Earl!
You're not the Earl Weaver that I knew, guess you get that all the time...
Wiring problems are easy to figure out, I just did mine on a 68 Roadrunner. It just looks intimidating ...........Just kidding. it really was not this serious. I disconnected and by passed the amp gauge. This is a big problem in 60s MOPAR. The gauge itself or the wiring at the bulk head connector can over heat causing a major melt down or fire. A lot of guys don't know about this problem, at least until it happens. Should you decide to do this, I have good info on how it's done. Welcome and good luck with the car. (That big wad of wires in the photo....JUST A JOKE, couldn't help myself.}
Welcome to the darkside...LOL
welcome to FBBO from NorCal
good luck with you 68 Coronet R/T project
check out http://www.madelectrical.com/
in the tech section a lot of great info
Welcome from Minnesota Earl.:welcome:
I would try a different speedometer gear if the speed isn't reading correctly. I just finished fixing the lights in my 1973 Charger, and my best friends in the process were a test light, sautering gun, sautering wire, heat shrink tubing, electrical cleanser, and new bulbs.
