My Z bar won't fit with new Ladewood bell housing
68383
12:25 AM
Worcester County
I upgraded to a Lakewood SFI bell housing for my big block stroker. Unfortunately, my stock Z bar doesn't want to mount in the stock location.
Anyone experienced with this? Do I need a different Z bar?
Thanks.
alternative thought--when i switched from auto to 5 spd tko in my hemi with shield i went with the hydraulic clutch and no problems so far.
I have a message into the makers of Lakewood.
I'd really like to use my center force clutch, Z bar and everything else, since I redid all of it about three years ago.
This is not surprising. I have an old Lakewood from the late 70's or early 80's and it required the ball to be mounted in an alternate location. You may just make an adapter plate from 1/2" steel and bolt it to the existing ball stud holes or weld it on.
On my mid 80's 2-piece Lakewood bellhousing I had to cut down the threads on the bellhousing-side Z-bar ball pivot. Otherwise the threads bottom out 2against the bellhousing making the stud stick out 1/2" or so too far and then the Z-bar seems like it's too long (tube length).
