American legend 18x8 in rear probably could of fit 18x10What rim sizes and brand did you use? Looks nice!
Is there a backspace size? Just wondering if it will fit stock. Thanks!American legend 18x8 in rear probably could of fit 18x10
And in the front 18x7
That’s a “ universal figment tool “. Just in case it’s needed lol..Uhhh...In this picture I see a lot of things including the Sniper EFI kit and a hammer.
I hope for your sake the conversion doesn't make you so mad that you smash things with the sledge hammer.
Holley told me there sending unit with pump would work and all I would have to do is drill a 3&3/4 hole but there is no spot to do it so now I have to call them so I can send the sending unit n pump back and they can send me there tank with pump and sending unit and floatWhat fuel delivery system are you going to use for the Sniper? That should be lots of fun to drive.
Already ran into a problem lol They said I could drill a 3 3/4 hole in my gas tank to fit they’re sending unit and pump but there is no spot that I can drill a hole so now I have to call them on Monday to see about sending their sending unit and pump back and getting their gas tank that comes with two holes afloat and sending unit with pumpUhhh...In this picture I see a lot of things including the Sniper EFI kit and a hammer.
It’s just stock, I believe there 4 or 4.5Is there a backspace size? Just wondering if it will fit stock. Thanks!
ThanksAsk about the upgraded tube type sender.... A few $$ more but the fuel gauge will actually be pretty accurate... The standard sender is junk...
If Holley doesn't have what you need you might look here..
Tank
1966-67 Dodge Charger, Coronet, Belvedere, GTX EFI Gas Tank
Pump
In-Tank Fuel Pump Module - GPA-Series
Sender
Floatless Fuel Sending Unit
My 66 charger suspension is completely stock I’m gonna lower the front torsion bars a littleIs there a backspace size? Just wondering if it will fit stock. Thanks!
Yes n yesAre you using the Holley in-tank pump? If so, are you using a return line?
I am going with the Holley Sniper also in the near future. Living in AZ, I am worried about using a return line located at the engine (and back to the tank) due to the immense heat, therefore heating the whole tank of gas and potentially damaging the pump in the long term.Yes n yes
Good luck with that.... You clearly don't pay attention...
