newbe-chiphlds
chiphlds
7:51 AM
methuen,massachusettes
hey guys,
newbe here,i have a 67 gtx tribute with a crate 512 stroker, rotisere restored.i have a problem.my oil presure runs at about 50-75 on the highway,but when its hot it idles about5-10.im using 5/30 synthetic.do you think if i went to 10/30 it would help or should i go ahead and change the oil pump. thanks.
welcome to FBBO
a bit more/thicker oil viscosity may help some
probably wear/extra clearances on the bearings & pump
easy enough to change the pump
right in front on the outside,
you could possibly just replace the pressure spring too
if the pump isn't that old or worn
it's under a roll-pin (? usually) & little cup cap on the pump
do a little research
be careful the B-RB engines with high volume
& especially High pressure pumps, with only a 5 qt oil pan
(doesn't look like it's a racer, so may not be any issue)
on older worn engines, a high volume pump is better choice
:welcome: from Ky. That's a helluva beautiful car! Oh yeah, I'm 74 also. :lol:
:welcome: sweet GTX clone,glad your here.:bananadance:
welcome to FBBO
as Budnicks says...
Also, I would question the Synthetic...
I think I read where the Synthetics are G-R-E-A-T for new style engines, BUT: something about the more precision machining and the Synthetic tends to "wick" away from the surfaces quicker etc.
Whereby the good Old American style original oil will stay on surfaces longer...
So, a good question, I will leave it to the experts on the Forum...
Welcome aboard from NJ. Beautiful car and thanks for posting the picture without us having to ask!
:thumbsup:
Great looking ride welcome.
Welcome from Missouri!!
welcome to FBBO
Budnicks is totally on target.
took it to a mechanic who has built race motors and he said i should be using oil with high zinc content like royal purple,and at least 10/40 or even 20/50 since i only drive in the summer.appreciate all your help
