Occasional no start mystery
Dibbons
2:14 PM
La Paz, B.C.S., Mexico
Once in awhile, first thing in the morning, my original '72 318 SSP won't start. The starter spins just fine, but no ignition. I know it has fuel because I first operate the carb accelerator pump by hand to squirt a couple of shots of gasoline into the intake manifold and I can feel/hear the gas squirt. Compression checks out fine and engine purrs like a kitten while idling. Must be ignition.
My first question is this: When the ignition ballast resistors fail, do they fail completely and forever or do they work one minute and don't work the next, and then work again later? Note:The vehicle has a new single point distributor (made in Taiwan, sold by PepBoys). The ballast resistor is two wire type, not four. Thank you.
once a resistor fails, it's gone.
You may have a bad coil. I suggest checking the point gap & dwell and timing to make sure it's all on spec.
This is good advice. Ballast resistors are all or nothing. I had a similar issue with electronic ignition (ignition box), but you say you're running points. You might also check your electrical connections to see if any are loose/corroded. Maybe it's the brown wire that bypasses the ballast resistor or something in the ignition switch???
As a side note, I just saw a ballast resistor for sale that was listed as "electronic", what's up with that?
This will have nothing to do with your ballast resistor as it is bypassed during ignition. Try another coil if you have one kicking around.
Could also be the ignition switch.Check for power at the coil in start & run mode.
Here is a good video on testing your coil, Plus an old points system could just have some junk on the points, when is the last time you sanded them clean / adjusted?
https://youtu.be/h8vSwfnX3Xc
that's a good video. Keep in mind that the coil resistance changes with temperature changes. The colder it is, the higher the resistance, the lower the voltage. Looking at the op's location, I doubt that cold temperatures are an issue but if your coil is on the edge of the spec, a cool evening or morning can cause trouble. Happened to my ram truck.
Or a loose distributor condenser wire shorting to the housing. If this happens all ignition current goes to ground.
Idle speed is 700 rpm, dwell checks out at 23, should be 30-34, I'll have to work on that tomorrow.
