One more 69 road runner build
pro-streeter
10:56 PM
Spokane wa
Starting on another 69 road runner build
Found this car sitting for 20 years in an old horse barn
Omaha orange 383 console automatic factory AC, disc brake, PS and tac option.
2E1C6C27-252F-4B7F-B420-78C2E496DE5D.jpeg BB03250B-4A11-46FF-9374-79E870B2D625.jpeg 305C2E95-E6B8-4D29-ACBB-1078BD4309F7.jpeg
Doors and fenders and other items are back from Blaster bodywork has started. 50+ years of dings, dents and the like. Good news is there’s no rust repair required all the metal is good
4F5EF2C4-C534-4906-8368-1AFD98A88C73.jpeg 86C05940-8E8D-4E45-A3AA-2362DF41BE87.jpeg 633F0D20-486F-42D2-86B6-D8B5CDB068D2.jpeg FDFBE110-80BA-4C0F-9F3F-360753720A61.jpeg
Nice work and a great start with such a good body. :thumbsup:
As I won’t be using the original numbers matching 383 on this build. I am setting it aside to be put in the car at sometime possibly in the future but for now I will be building a 505 Cubic inch 440 stroker.
The transmission is a non-numbers matching 727
I’ve had the transmission modified and built by Jed‘s street/strip racing transmissions Spokane Valley Washington.
The following is some description and photos of the modifications.
We first started by completely tearing the transmission down having the case ran through a parts washer and then glass beaded.
704D80B6-2EE5-4464-B123-0CD5E05E70CE.jpeg 81CFD17E-D11A-4C8B-972F-76ABA5FA55A7.jpeg FC925A06-3EE2-4FEE-8492-8E0ADB0D3F48.jpeg
We opened up some of the fluid paths by drilling and or chamfering the holes as pictured. The chamfering process is a little touchy as you do not want to damage the land on either side. The chamfer should measure a proximately a quarter of an inch. The other holes in the spline are drilled out just to the edges of the spline itself. As I have come to understand these are minor modifications but every little bit helps.
F2E5AC9A-20C5-4E29-959F-099B76EDF66A.jpeg 0FF9A664-C368-46E2-8EB7-296020120B0C.jpeg 4508C0A8-8858-48ED-8825-85A194B79C5D.jpeg
The transmission had a three pin planetary originally in it. We have swapped it out for a four pin planetary. This allows for more gear contact and engagement.
We cleaned and reused the original rear drum.
A72004C8-5713-42F5-9DC4-41B84BFE905D.jpeg C5E73D45-61F7-4C03-A561-47641ACC2B16.jpeg
We disassembled and cleaned the tail shaft bearing and governor. We used a new governor kit supplied by Cope racing transmissions.
5FBEDCFB-1A27-4281-BDF4-F3A504164906.jpeg C5426F2A-AA63-489B-A8D5-C18D01681420.jpeg
When installing the rear and front drums new bands were installed from Cope. CRT.
We’ve installed our billet steel front drum to replace the stock drum. This is a key safety feature also sourced from Cope racing transmissions. CRT
93D34784-F3CD-4011-953F-3D67ECD27A96.jpeg CD703B9C-2BC7-4307-B8C2-D027234270F6.jpeg B4E221DE-BAE4-4855-80B8-91AAA6FC8517.jpeg
Installed a lighter servo piston. We then replaced the servo retainer and installed the band arm. You can purchase different arm ratios that allow for more band leverage depending on your needs or application. CRT supplied.
5EE4666F-302A-4530-9406-1DD90485925F.jpeg B2C7C99C-D6D0-4564-B55C-D2D54D6D042D.jpeg 05B26503-0F16-458D-B9A3-DE9CE53C7AD4.jpeg 825854F3-6284-4FCE-B275-B1F7E81B6C02.jpeg
