AmericanPowertrain
Agree and disagree
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here is the link to the entire Moparts thread:
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=4787748&an=0&page=1#Post4787748[/QUOTE]
TRUE1. For a true "no hack" install the nod CLEARLY goes to Passon
I disagree. Up to about 6200rpm the Tremec TKO (Keisler does not make any transmissions) can be speed shifted. You may have driven a few older TKOs that did not have micro-finished lugs, which made the 2-3 shift a chore. Also, if you are using a Keisler hydraulic system you may be getting clutch drag, which limits high rpm shifting. I would at least give the two a tie.2. If you drag race you'll like the Passon, the Kielser is not a fast shifting trans, a bit too sluggish and notchy, especially at higher RPMs
Not true at all. Static torque testing at Tremec proved the TKO600 up to 1400ft-lbs of static torque. I have sold over 2600 TKO transmissions and have only two failures under load. That is a solid track record from personal experience.3. If you want the strongest trans, Passons will take more HP than a Kielser by a fair margin
Can't argue with that!4. For cost and ease of install, Passon wins
Agreed5. For the best highway crusing O/D situation, Keisler wins due to it's better high gear ratio
Again, I agree that the Tremec wins, but Classic, American Powertrain (taking a bow) and Keisler all base kits on Tremec TKOs.6. Fuel milage Kielser also wins, same reason
Check out Classic or AP for much better customer service than Keisler. We even have a 24-hour tech line. Passon gives great service too.7. Service - Passon hands down
Yep, OK8. With a 3:54 geared car that you do not want to modify beyond clean/simple easily reversable bolt ons and is mainly street driven and occasionally drag raced - Passon
We can mod the TKO to take 11,000 rpm shifts if that is what you are into. Keisler used to be the only player, but not anymore!9. For a modified car that is mainly used for local car shows, street cruising, taken on a good many long highway runs and not much else -
I feel so abused. Not even a mention of American Powertrain. Ya'll don't know what you're missing. :edgy:10. If considering these two companies you should also look into Gear Vendors and Classic 5 Speed before buying, may as well see what everyone is selling before you pull the trigger. I have also driven Gear vendor equipped cars, they should be a consideration for sure, they make a good product.
