joew94th
About 3 weeks ago my OEM radiator sprung a leak. I have never had a cooling problem until then. Even on hot days, the 360ci in my '66 Belvedere rarely went above 190 degrees. I decided to replace the radiator with a brand new universal fit aluminum cross-flow radiator from Summit. I also replaced the flex fan with an electric one. I installed new hoses and a 160 degree thermostat, 50/50 mix of antifreeze & water. Everything is fine at idol, about 190 degrees after 10 minutes. The thermostat seems to open at the right time and I can see the coolant flow, so water pump is working. One trip around the neighborhood and the temp goes up to 250 degrees and radiator boils over. This radiator is about the same dimensions as the old OEM copper radiator. I've read that cross-flows are supposed to be more efficient. The one difference is that I no longer have a shroud. It's hard to imagine a shroud would have that much difference.
Any help is appreciated!
