Pull a string on center line of trans and diff if they cross you have trouble
Also take string from centerline of diff and adjust for axle wrap 2 or 3 degs
Not replying, just asking more questions. Sorry purist but now have a 4 link 3rd member and have a gear vender on the 727. Right now before any adjustments have numbers in the 6/7 degree area. The offset is as follows 7.1 / 6.9 so if I understand it is with in what is suggested as ok, but is way to much total?? seems as if have read max 3 and respective keep offset within close as possible?? thanx so much for any helpful advice
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
