68 Sport Satellite
I have never come across a slick trick for this. I fight it every single time. Do any of you have a trick or preferred technique to reinstall a water pump pulley/spacer/fan to get the stupid bolt holes to all line up and get the bolts started without the spacer falling or spinning twenty dozen times and success only comes by luck? I was thinking double sided tape? Is that the only way? I could pull the rad out, but I don't really want to and it would still be the same problem, just a little more room in front to see.
Thanks in advance
Thanks in advance
