Post your 10 second combo's
First time with a 10 N/A in this car.
440 .055 over
Victor MW cncs
270@ 50 ish solid roller
Indy 4500 intake
1050 prosystems dominator
5500 ish ATI
Big TTIs
Was in the 11.30s @124 with 30.5" tires and a 3500 converter. Swapped to the 5500 and 28s. First decent run nailed a 10.53 @125.8. The trans had issues with delayed shifting so that was on the 7000 chip every shift. Bumped up to 7200, and while the trans got worse, pulled 127, still on the chip at the top. 1.47 60'. So there's more in it with a trans and some tweaking. Never touched the carb, or timing(32°).
All steel 67, stock driveshaft, small joints, 8 3/4 4.56 shitty S/S springs. Calvert front shocks and some old rear truck shocks. Lots to do drivtrain and suspension wise. But hey! It was a hell of a Lotta fun!
What's the comp ratio you are running? Pump gas or race fuel? Sounds like a nice ride, heads and cam really allow that thing to breathe nice and free at 7200, huh?
It's around 11.5-12 likely. I never cc'd the heads. Runs on C12. From what I've seen the heads should flow about 380. They came off an aluminum 572. We're keeping the RPMs down due to the factory crank. If we really let er buck it would want to see about 7600 I suspect.
How is your low end torque on the max wedge versions, do you think its been killed by too big of head, or not?
Low end torque????
:rofl: :rofl:
It's not a motorhome, we're racing here!!
Oops forgot the thread I'm in...
To put it in perspective, it was about 11.40s and a 1.85 60ft with a 3500 stall. Then 10.50 with a 1.47 60ft, 5500 stall. So almost a second gained with a 2000 rpm launch increase
Stock 440 port window is about like a small block chevy head , I think ALL performance 440 & up should have a max wedge port size.
Max Wedge, now we are talking!
No torque just max RPM's...:mob:
2-1/2 inches tall and 1-1/4 wide that's proper induction.:luvplace:
Finally got the 66 satellite to the track. Though it would do a bit better.
Car is heavy 4,050 race weight. 3800 without me! Trans brake not holding so had to foot brake. This is with full 3” TTI exhaust, 35 degrees of timing, and leaving about 3000 rpm. Did pull the wheels for about 8’ though which is cool. Car hooks good. Just feel there’s should be more in it. Motor made 736hp 680tq to the wheels. Shifting at 7k. Probably should shift higher, going through the traps at 7k. Drop from 7k to 5470 on the gear change. (Data logged) Lupo 9.5 converter stalling at 4500’ish on foot brake.
It’s been a long time coming. Especially the last few hundredths. But I’m now here in the 10s.
Build is a Factory Appearing 1968 383 using a 400 block and Eagle 4.15 crank with their rods and Ross pistons. A Porter Racing Heads designed cam works the 2.14/1.88 valves with Comp solid rollers. Chrysler iron open chamber heads control the 14.5:1 compression. A very worked 301 iron intake kills any power that the AVS carb might try to supply. Any power that did sneak through the top of the engine is killed in the factory exhaust manifolds and 2.5” full exhaust.
A PTC converter sends power to a rollerised and Randyised 727 and a 3.91 8 3/4.
Bill Atwood took all this junk that I brought him and assembled into a decent running race car. ️
There is (almost) no such thing as a too-big head for a stroker bbm.
EM did a dyno comparison of a 240 TF, and a 270 (small size mw port). The 270 was better everywhere, even torque at the bottom of the pull.
Bbc heads that are 400+ cc's, and 500cfm are available. You only need to write a check.
