Post your 12 second combos
Took my 70 challenger out last weekend ran a 12.35 at 111 mph best with a 1.82 60ft
full weight car, at a guess at least 3800 with driver, 440 with hyd cam, think it's around .500, dont know comp but it runs on pump without issues, full port 906 heads no flow numbers, victor int, 850 dp, reverse pattern 727, 3800 converter, 4.10 suregrip, 28x14 M & H slicks.
I can finally post in this forum I took the car to the 1/4 track last night and it went 12.58 @ 109
combo
1965 belvedere 1 wagon
1969 .040 HP 440
906 heads with big valves
12:1 arias pistons and eagle rods
23 spline a-833 trans stock
McLeod soft lok clutch
8 3/4 rear with spool and 4.56 gear
29.5 x10.5 M/T slicks
weighs 4100 pounds with me in it
combo
1969 .040 HP 440
Congrats on 12's in that heavy car. Ron
my Engine has a .550 flat tappet with a 1.6 HS rocker and a eddy torker intake!
12 second B Body
67 Plymouth Satellite
360LA/727/4.30 gear.
3850lbs with driver
12.67@107MPH..
Street car.....
Nice Satty Dr. Mopar
I remember that car & the name from another forum maybe ? MMM
cool ride
I just went to the track this weekend and ran a best 12.51@108mph with 1.94 60ft. My combo is
440 30 over 10.6 compression stock crank and rods
Eddelbrock open chamber heads 2.19 1.88 valves w/no other mods
single plane weiand with 830 mighty demon double pumper
727 with manual shift valvebody and 4200 stall
3.55 posi 8.3/4 275 50 15 bfg drag radials
hooker 1 7/8 headers with 3 inch exhaust and dynomax mufflers to axle with turn downs
NOS BIG SHOT SYSTEM next.
1964 Plymouth Savoy Wagon - 4120:lbs
440 stealth heads, 10.6:1 compression, mechanical cam, performer RPM 800 holley, 727 3200 stall, Rmvb, 4.10 Dana 60.
12.28 @ 111 MPH
12.28 @ 111 MPH
You should have went right to the 11's section. :)
ET 12.87 MPH 109.26
4000 lbs Dodge Charger with street tires and 3.23 Sure Grip...
451 Cid with Performer Edelbrock heads, Performer Rpm intake and Mr Six Pack cam.
[video=youtube;tt-x-_3jjmE]https://www.youtube.com/watch?v=tt-x-_3jjmE&feature=player_embedded[/video]
combo
1969 .040 HP 440
Finally ran some more 1/4 mile this weekend and with some clutch tuning and the dual carbs it went 12.21 @112 with a 1.67 60'
