Mine leaks so bad I can't drive the car without puking fluid all over my driveway and the road. I've been putting aluminum pans under the K-Frame and a small bread pan wedged inside the K-Frame to catch fluid. I have to empty the small bread pan every time I run the engine to exercise it. I haven't driven my car in 5 weeks because of it.. I bought the car knowing it had this problem. The previous owner ran DEXRON ATF fluid in it, because PS fluid was too expensive to keep putting in it when it leaks so profusely.
I will be replacing this old leaky POS with a Borgeson gearbox, pump and lines. The list of pluses with that system was too great for me to bother rebuilding this old, big heavy gearbox.
This photo below shows the soaked pitman steering arm. The bread pan, under the front of the gearbox, almost totally fills up only after starting and running the engine till warm once! My K-Frame also gets covered with the stuff. It is a mess!
