Ram Owners washer squirters on hood icing up blocking them...
QuickBpBp
12:11 AM
SE PA
I don't know if this is an issue with all Rams in cold wet weather but with my 2017 Ram 2500 the squirters freeze up from snow settling down in the squirters or after a rain and the temps go below freezing. I tried all kinds of different fluids and it's the squirters. So long story short it's been snowing around here so the roads are a mess with salt and they froze up again making it a mess to see out the chalk white windshield. So a few days ago I tried using them after getting some engine heat to thaw then and nothing. I could hear the washer pump running every time but nothing came out. So the washer pump finally quit the other day so today I had a chance to check it out. Tried finding a fuse thinking it could have blown. No fuse. So I thought I fried the washer as this has been going on for over 7 years in winter. So I thought let me look online and see if there is any issues to resolve this after I replace the pump motor... So I read about how one guy says his motor stopped working and all he did was blow back through the line till he heard bubbles in the washer reservoir. So I went out after reading thinking what can it hurt, costs nothing and it's simple. Popped the hood open, saw the connector at the cowl, popped the hose off blew into it heard nothing then blew again and heard the bubbles in the tank. So I lowered the hood, hit the washer fluid then heard the pump instantly and it works fine again. So if you end up having this issue chances are this will work for you also...
I used to do something similar many years ago
RAM charges an arm and a leg for their 2500 series trucks and they don't come with heated windshield washer nozzles?
Sorry Brett, all I saw was trouble with squirters....and I lost what you were on about. :rofl:
Seriously - have you tried the Wurth brand of windscreen fluid? I use it and it is awesome - no chemical reaction on paintwork, and it helps to keep the lines (tubes) clear and clean.
I got my buddy to get me a 5 litre (a bit more than a Gallon) bottle of it a while back. All the regular crapola like Bars Bugs is crammed with Chlorine and detergent which eventually corrode bodywork, and stain paints....also rust out the wiper arms.
Wurth fluid is orange in colour.
Picture below shows the retail 'one-shot' bottles that most Mechanics will sell you - but it is cheaper to buy the big bottle with a pump dispenser.
Two threads with one picture.... this is my big bottle....smaller capsule is to catch the drips from the pump.
LOL. But I may actually try to find an aftermarket set....
Too Funny. I can always count on you Roger!!! Any way I think the issue is the fluid bleeds back and allows the water in. I have already poured just room temperature water on them and the work instantly. It's just frustrating but the big thing for me was just having to reprime the locked up pump motor allowing it to work again by blowing back through the system.... Supposed to snow here all day Sunday and be about 1 to 2 degrees for the lows here Monday-Weds nights so I am sure I will be dealing with them frozen again!!
Always happened to my '98 GMC. I installed a small check valve in the squirter line so they can't drain back... so the deice fluid sit in the nozzle.
Thanks Wayne I thought about that too and just wondered if it would evaporate in the mean time allowing for enough room to do the same thing. Cheap enough and easy to do so I might order one online and try that.
In 2012, we were driving our 2008 Ram across southern Wyoming in January. The temperature was minus 20 degrees Fahrenheit and blowing snow and we were not able to clean the road spray film from our front windshield due to blocked nozzles. I had the foresight to put a spray bottle filled with washer fluid in the truck and I would spray some of that on the windshield when needed. I always carry a spray bottle with washer fluid when traveling now. I finally figured out the washer fluid was freezing in the nozzles/tubing due to mixing with water when sitting. I add a bottle of rubbing alcohol to the fluid jar when I get in low temperatures with snow on the hood and have a full bottle of washer fluid inside the truck within reach.
Terry W.
Terry W.
Exactly. That's why I asked earlier about what kind of fluid was causing the issue. Most will only protect to 15 or 20°. Think about it fellas. WTF happens to a small opening the size of a tag wire and a rubber hose exposed to 0° temps at 60 mph. Use your head!
This stuff never failed me when I lived in upstate New York. Also, had a spray bottle of it so I could get the doors open. :)
The heated w/s washer nozzles were nice too.
