Ring and Pinion set identification.
fbs63
2:37 PM
Lowell, Indiana
I am trying to determine how to tell if a ring and pinion are a set. Not the ratio but if they belong together as a set. I have a Dana 60 4.10 ring and pinion a customer wants me to set up but it has some odd wear marks. I checked the serial numbers on them and they are about 3000 numbers apart in series. I also checked 4.10 and 3.73 sets that I have and they are consecutive in numbers. I suspect the ring and pinion don't belong together but the customer states they were running together. Anyone have insight on this? Hate to go through setting it up only to have it noisy because they don't belong together.
I'd say they are not a match. Be careful and tell the guy if he wants to use them you are not responsible if noisy.
You get what you get with used parts.
I’ve seen plenty of ring gears and pinion gears with an etched in number that match each other. Look at the head of the pinion gear and the side of the ring gear for what looks like someone used a scribe. I’ve seen this on a lot of factory gears. I’ve also seen where these numbers are not present. It will be hit and miss.
Look close and you will see a 174 on both of mine. Pinion gear below
