Rings won’t fit in grooves on pistons.. HELP!
67charger383
7:52 PM
Maryland
I’m partway through building the bottom end of my 383. I was just about to gap the piston rings but when I test fit them they won’t go in the grooves on the pistons…
Do I need special rings or something? 30 over TRW L2293 dome pistons and Hastings 30 over moly rings.
If they wont fit they obviously are wrong. What are the piston ring lands measuring? What do the rings measure.
These rings came in a bottom end rebuild kit that I bought and specd 30 over rings.
the new rings and the old factory rings are the same height and both fit Fine in the groove on the factory pistons but neither will on the TRW domes… I guess these pistons require special rings that are different than factory spec? Someone on this forum that has run a set of L2293s has to know
Your rings are most likely 5/64 and you need 1/16. So you most likely ordered the wrong rings for the pistons you intend to use.
How would I measure that? I just ordered factory replacement rings for 30 over pistons not knowing that they could be different
TRW piston aren't factory pistons, my TRW's 1/16, 1/16 and 3/16 think that is what TRW's use.
Here is a piston from ebay. Looks like it has a 1/16,1/16,3/16 ring pack. Looked your Hastings rings up on summit and they are 5/64, 5/64, 3/16
The world is a scarry place sometimes.
Late to the party. TRW dome pistons are 1/16.
(Clicked on to see if he was using used pistons with pinched ring grooves. Guess the answer is much simpler).
Is this your first engine build? My first 'overhaul' was done without any measuring tools and well, imo I lucked out that everything worked well. Over the years I became a machinist and learned that you CANNOT trust others to make sure things are right. If you plan on building more in the future it would be a good idea to get some tools to measure things. They will pay for themselves over time....and the first time an engine expires during a cam break in, you will spend a lot more fixing it than what the tools cost.
The whole thing went south when a "kit" was bought and the rings were for stock pistone and the OP had TRW"s. That will happen. Like a gasket kit for your 318 and you have Edelbrock heads and intake. Of course the gasket's aren't going to be right.
Still not a bad idea to measure the parts. It doesn't happen very often but there have been times when the parts in the kit weren't right. And if the machine work on the block etc isn't right, the parts in the kit ain't gonna fit even if they are the right parts lol
As a former engine builder as a proffesional, I can say most hobbyists don't see it this way. It's just a bunch of parts you take out of the box and bolt together. I still do assembly as a hobby/side gig, as I still have all my tools, and it can take several days to get all the clearances right, pistons assigned to bores, rods assigned to journals, etc. Most guys are just lucky. I'm not.
