66 Sat
A. It's not necessarily abuse - that's what I'm trying to establish.Shifting from third to second on acceleration is what kickdown linkage is for. I see no reason for the manual abuse.
B. There are definitely times when it's needed. There is no part-throttle kickdown, so to change to 2nd I need to floor it using the kickdown. If I'm slightly above the threshold where it will kickdown, I'm left in D accelerating. but not that fast. If I want to make a quick overtake I want maximum acceleration, so need to manually shift to 2nd instead of flooring it and hoping it's going to kickdown. I can also hold the gear to redline, instead of the transmission changing up early. I've read the factory '68 hemi cars would hold on until 5,500 rpm before upshifting. Mine isn't calibrated like that and changes up at about 4,000 rpm. I could probably get all this changed by spending money but if it isn't harming the transmission then I'm happy carrying on using the manual shift.
There must be some auto trans experts on here who can answer definitively.
