Satellite rear seat window cranks
AR67GTX
10:58 PM
Arkansas
My car has smaller (shorter handle) cranks on the rear windows which I suspect are vent cranks off a 66 “C” body. But just to make sure Mother Plymouth didn’t do something weird in 66 I’ll ask the question - window crank handle lengths front and rear should be the same correct. My 67 has the same cranks front and rear.
Jerry - those are listed for 63, 64 and 65. But they used them in 66 too?
They should look exactly like your fronts, only a little shorter.
OK - thanks. Another 66 vs 67 difference.
Probably OER or PG Classics. They have been available awhile.
I just measured mine, and am fairly confident they are replacements. "THEY MIGHT " be NOS. They look to good to be originals. Previous owner was on a mission too use as much original/NOS parts as he could and avoid repops if at all possible
BUT,,,i would need to clarify with the previous owner to be sure .
BUT, fronts are 3-1/2" center to center length
Rears are 2-5/8" center to center length
66 rear cranks are shorter than the fronts...but...
there's no reason they need to be.
The machinations of the 66/67 rear windows require torque and those puny, short cranks struggle.
You absolutely can use the longer frons cranks for the rear, and operating the rear window becomes MUCH easier.
