you dont need the solenoid ,my Bee with 4 speed6 pack had a fast idle solinoid from the factory also
I am still putting my car together but it is running and moving on the engine and have not had any troubles with out one
so this guidance is wrong for adjustment of the idle?All 3 carbs affect idle, they all contribute. That's why we like Promax base plates for the end carbs. I do not disconnect the ends except for removal.
Way off track, I'm out.
It’s been a long time, and The DC manuals are buried. But I followed the procedure they recommended for the Six Pack setup. Mind you, I have headers on both cars and a slightly more aggressive cam. They basically said the carbs were all jetted to lean from the factory. They recommended two steps up on the main jets in the center carb, a power valve that opened sooner, a bigger squirter for the accelerator pump, and backing out the idle screws a quarter turn more from the factory recommended setting. Also on the outboards, remove the lead plugs and back all 4 of them out a quarter turn. Then the metering plates were to be pin drilled out to .08? Been a while… finally I think it was the yellow springs in the vacuum diagrams. I did it and it was the most responsive Six Pack setup I was ever in. Many other guys that had the Six Pack that I talked to complained about an off idle stumble and bogging when the secondaries flipped. Those DC guys figured it out. I recommend trying the mods.
id love to have a copy. its not this one, is it?
Good luck finding that solinoid! You don’t really need it! As far as special linkage, nothing needed for a standard equipped vehicle other than the throttle cable6 pack had a fast idle solinoid from the factory also
I came across one from a 340 cruise control set up that appears to be the same so grabed itGood luck finding that solinoid! You don’t really need it! As far as special linkage, nothing needed for a standard equipped vehicle other than the throttle cable
Attaached are fresh pictures of my 1970 Cuda 440-6 with manual transmission. I realize this is not a B body, but thought it could help. The factory spring is a single one and is purple. I added a second spring for backup. You can see this in the center of the purple spring. The idle solenoid is installed but is not used. Even with a slight performance cam, I was able to tune the car to idle at about 800 rpm. So not run on and eliminated the solenoid usage. Hope this helps.
Ordered a new throttle cable from Imperial a couple weeks ago, i guess they make them to order. will be another 2-3 weeks.
ProMax sells a setupthanks, its not completely stock, has jetting tuned from Promax for my setup with their metering block.
anyone have a recommendation for where to buy 6AN braided fuel line?
I bought one on eBayso for everyone around here, maybe it comes as no surprise, Imperial doesnt answer the phone and i am almost certain ill never see the new throttle cable i ordered 3 months ago.
Anyone know a better place to get a real correct length 6 pack throttle cable?
I used this guide.correct length, according to 6 pack performance, is 22.5".
Sure. The Six Pack is great fun when tuned correctly. A real Rush when you nail it!well, finally got the new throttle cable and i believe the above is right, 21" is the correct length.
Now, allegedly, I have everything to do the swap. but i am hesitant to jump right on doing it. worried ill have buyers remorse, but I dont think i will.
anyone got some motivating words to push me to take the plunge on the Six Pack?
You will not regret it, when it opens up the smile will be on your face.well, finally got the new throttle cable and i believe the above is right, 21" is the correct length.
