I'm very curious about the vacuum set-up you have. Normally, Holley carburetors have an internal passage that provides vacuum to operate the throttle blades. Why is this hose and valve necessary?
That hose IS what provides the vacuum signal to the outboards because of their remote nature (separated from the center carb).
OK, I'm seeing this valve, which is not stock at all. Seems it's purpose is to bleed off some vacuum signal to ATM so the outboards don't open so fast. But Holley thought of that too! If you remove the vac diaphragm you will note the bleed off hole that passes right into the main venturi. I have seen two sizes. Approx .067" and .043" and the larger of the two holes will slow the opening of the outboard carbs. Also in my experience the outboards don't open in a linear fashion. It's quick until about half way then very slow to not at all depending on the diaphragm springs. Seems it should be reversed and perhaps the PO of your setup was onto this, hence the addition of the bleed valve.
Meep & Colorado
Sorry I got this off track. The valve is a vacuum bleed, just adds a little more adjustability to the end carb opening. I ran my other setup very near stock & worked great. Modifying end carb jet plates & drilling holes got my first setup off track. Got back to nearly stock & problems solved. The setup in the picture was done by a fellow around here that did the carb & ignition work on several of the hard running Stock/Super Stock guys in the early & mid seventies. The pitured stuff ran perfectly.
