4mulas
- 11:44 AM
- Mar 16, 2017
- Just North of Great Falls
Hello, thinking I want to order a sniper but have been told and have read a little bit on low LSA’s giving grief on, i think, the idle circuit?
im planning on using it on a mopar P5007647 402 crate motor. It‘s a magnum 402 with a roller cam that apparently has an lobe separation angle of 108, motor also uses an m1 intake, which leads to another question.
Does it matter if you put the sniper straight onto the m1 small block intake which I believe is a spread bore style? The MP catalogue for the motor recommended a 4160 style Holley 750 carb (p4349228). The same description for the motor also says the engine is not intended for use with stock tpi injection. Is this because the stock wouldn’t fuel enough or the aggressive cam confuses the EFI?
really hoping @andyf might see this too as he’s had EFI installs with aggressive lsa’s..
