So I got a bet for you...
Heating, Cooling & AC
  1. Daliant
    Daliant Active Member
    36
    42
    Jul 17, 2017
    Lockport, NY
    Local Time:
    3:30 PM
    Both engines being identical and under the same load will produce the same amount of heat, both radiators being identical will remove the same amount of heat. The thermostat becomes irrelevant once it's open so if both cars start the run at 180* they will both be at the same temp at the end of the track with all things being equal between the 2 cars.
    • Like Like x 1
    • khryslerkid
      khryslerkid FBBO Gold Member FBBO Gold Member
      19,085
      27053
      Mar 10, 2010
      Hanover, Pennslyvania
      Local Time:
      3:30 PM
      Both identical engines...
      • Like Like x 1
      • Agree Agree x 1
      • KENTON
        KENTON Well-Known Member
        736
        783
        Feb 25, 2014
        chicken coop
        Local Time:
        1:30 PM
        the answer is too simple. But can anyone tell us why the chicken crossed the road? If a tree falls in the woods and no one's around, does it make a sound? Thats whats been bugging me for years.
        • Like Like x 1
        • Ranger16
          Ranger16 Well-Known Member
          3,244
          3817
          Jun 27, 2016
          Woodstock Ill.
          Local Time:
          2:30 PM
          I suppose Stant is not a good source either?
          • Like Like x 1
          • WileERobby
            WileERobby Well-Known Member
            6,216
            7253
            Sep 15, 2009
            State of insanity
            Local Time:
            3:30 PM
            And why wouldn't that be true ? Again, as I stated before, the thermostat sets the MINIMUM operating temperature. If the cooling system is operating efficiently and has ample capacity, it will set the coolant temperature at its specified temperatures. So, yes, the 180 will operate cooler than the 190, system permitting. They raised the thermostat temps for higher operating temperatures for emissions purposes.
            • Agree Agree x 3
            • WileERobby
              6,216
              7253
              Sep 15, 2009
              State of insanity
              Local Time:
              3:30 PM
              Yes, you're right it's misunderstood. The pressurization does indeed raise the boiling point, but you're not using water alone. The coolant additive also raises the boiling point above 212f. But the reason the boiling point needs to be raised is not for operating temp. If a water molecule is in contact with the metal surrounding the combustion chamber, it will immediately absorb heat and evaporate. Gas will not absorb heat like a liquid, so the boiling point must be raised to maintain the coolant as a liquid, to continually absorb heat. The combination of water (the best conductor of heat), coolant additive and pressurization, and continual movement of flow enables the liquid to absorb heat and maintain its state as a liquid.
              • Agree Agree x 3
              • HT413
                HT413 Semi Pro Bowler
                5,404
                5340
                Jul 5, 2012
                New Jersey
                Local Time:
                3:30 PM
                Have any of you ever seen a baby pidgin? Seriously, are pidgins born full size? Because I’ve never seen one.
                • Like Like x 2
                • Agree Agree x 1
                • Ranger16
                  3,244
                  3817
                  Jun 27, 2016
                  Woodstock Ill.
                  Local Time:
                  2:30 PM
                  WOW! "Misunderstood" seems to be an understatement.
                  • Agree Agree x 1
                  • khryslerkid
                    19,085
                    27053
                    Mar 10, 2010
                    Local Time:
                    3:30 PM
                    Baby pigeons are called squabs.
                    • Like Like x 1
                    • Thanks! Thanks! x 1
                    • WileERobby
                      6,216
                      7253
                      Sep 15, 2009
                      State of insanity
                      Local Time:
                      3:30 PM
                      I thought you clean your ear with a squab.
                    • mykers
                      mykers Well-Known Member
                      82
                      84
                      Nov 16, 2017
                      Fullerton
                      Local Time:
                      12:30 PM
                      Sorry for the late response guys...some family emergencies kept me away. Anyhow, I making my disclaimer now: I had to go back and get the answer from glen (old guy) because after trying to understand this I'm still pondering. What I mean by this is, it seems logical and counter-intuitive at the same time...errr, you be the judge!?! Remember, don't blame the messenger :BangHead:
                      Answer: It all goes back into the design of the motor. The intake and exhaust valves were located on opposite sides of the combustion chamber at 90 degrees to the cylinder bore axis, so separate individual rocker shaft assemblies (two on each head) were necessary to operate and control all sixteen Intake and Exhaust valves. It also centralized the spark plug location, making the flame travel shorter, thus more effective in lighting off the air/fuel mixture.
                      It also gave the combustion chamber, greater thermal efficiency. These engines run cooler because of having a greater surface for heat transfer along with large cooling passages, which negates the existence of a running a thermostat or having one in under optimum temperatures. It’s the outside temperature of the engine that is key to this story...meaning under the hood before and outside the hood/in front of radiator.
                      And I know what your thinking mike…Sorry, but the coolant "flowing too fast" is a myth. The thermostats job is NOT to slow down the coolant so that it can cool better. Basic thermodynamics would have us know that the heat transfer is greater when the temperature delta is greatest (i.e. the more there is a temperature difference, the greater rate the heat can be transferred between the two surfaces). I am sure that there will be many stories of how this is not true, but you should probably argue with the engineers that designed this engine if you don't believe it. Why would you own an engine designed by engineers that you don't believe anyway?
                      END
                      Remember...I had to record all of this! I am not a hemi guy. I just switched gears from an Oldsmo guy to a Mopar guy. I'm happy I did! I love my 70 roady, but this makes my head hurt. Plus, maybe he had a few wires crossed. Either way, maybe its good knowledge or a laught...you be the judge :bs_flag:? :thumbsup:?:mad:?:BangHead:?
                    • mykers
                      82
                      84
                      Nov 16, 2017
                      Fullerton
                      Local Time:
                      12:30 PM
                      I think the point he was trying to drive home was "It also gave the combustion chamber, greater thermal efficiency." the fact that one had a thermy and one didn't is irrelevant. That's my take anyways.
                      • moparwacko
                        moparwacko MASSIVE GOLD MEMBER FBBO Gold Member
                        1,760
                        3890
                        Mar 14, 2015
                        Pa
                        Local Time:
                        3:30 PM
                        So, if my lava lamp had hemispherical design would it produce larger or smaller blobs?
                        And would the said blobs then travel faster?
                        And would the said blobs travel in a swirl pattern?
                        Or would i need a "Magnum" design for that?
                        • Like Like x 2
                        • khryslerkid
                          19,085
                          27053
                          Mar 10, 2010
                          Local Time:
                          3:30 PM
                          Did Glen run a lot of methane back in the day?
                          • Agree Agree x 2
                          • Like Like x 1
                          • HT413
                            5,404
                            5340
                            Jul 5, 2012
                            New Jersey
                            Local Time:
                            3:30 PM
                            Hey guys, what oil do ya run? I ran into an old timer that said West Texas Intermediate was all he’d run... right off the derrick.
                            :elmer::steering:
                            • Like Like x 1
                            • mopar 3 B
                              mopar 3 B Well-Known Member
                              8,680
                              6040
                              Aug 25, 2014
                              Kingsville, MO
                              Local Time:
                              2:30 PM
                              The engines were probably never started and the cars were pushed across the finish line.
                              Stock factory hemis never came with twin cams.
                              Can poke all kinds of holes here.
                            • Roadcuda
                              Roadcuda Well-Known Member
                              224
                              125
                              Jul 17, 2008
                              Central, Ct
                              Local Time:
                              2:30 PM
                              Interesting discussion. But in reality how often do engines built to the same specs, in cars built the same way, run identical times. To me there are too many variables in drivers, the cars, track lane conditions, and weather conditions that would affect the times. Now with that answered, why did the chicken cross the road? To prove to the squirrels it could be done of course.
                              • Like Like x 1
                              • not so famous bob
                                not so famous bob Well-Known Member
                                1,697
                                1118
                                May 20, 2016
                                okla. 74021
                                Local Time:
                                2:30 PM
                                yeah, their ugly as hell !!LOL
                              • Fran Blacker
                                Fran Blacker FBBO Gold Member FBBO Gold Member
                                6,790
                                6310
                                Sep 23, 2016
                                Connecticut
                                Local Time:
                                3:30 PM
                                Another "Which came first the chicken or the egg" theory .
                              • meskip
                                meskip Active Member
                                41
                                11
                                Nov 16, 2014
                                West Central PA
                                Local Time:
                                3:30 PM
                                I'll go with the theory that the story teller ran to much methane when young.
                                • Like Like x 1
                                • Agree Agree x 1
                                1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
                                  By continuing to use this site, you are consenting to our use of cookies.
