My opinion....
The std 318 2bbl came with Champion N14Y. After l installed 4bbl, 273 Hp cam and manifold and recurved the Prestolite dual point distributor, i switched to Champion N12Y. After rejetting the carb and a little quicker advance, l changed to Champion N11Y.
Depending on your specific conditions, you may want to consider N10Y (std hemi plug).
Ethanol blended fuels, depending on the ethanol percentage, may require significant richer jetting, because the higher percentage of ethanol in the composition will result a cooler burning condition that MAY need a slightly warmer plug. Its better to start out with a colder plug than to damage the engine. Which brand of plug to use is up to you.....the NGK boys have their favorites, the same is true for Autolite, Bosch, E3, AC, etc..... I have found NOS Mopar on line as well as the other brands.
Just my opinion of course.
