I HAVE DONE THIS EXACT SWAP!!!!!
http://www.forbbodiesonly.com/moparforum/showthread.php?1121-B-Body-stiffening[/url]
Please read my build thread, you can start about page 12 to get to the wiring/computer nightmare part!
Bottom line is this. if you do not get the tone rings and speed sensors from the donor car (5.7& NAG!) moved over it is NOT going to work.
What I ended up doing AFTER I had the engine, NAG1,complete dash and console, complete wiring harness,and even the HVAC system mounted in my 70 GTX from the donor 07 Charger. The only thing I did not fit in the GTX was the rear axle assembly from the 07 Charger,which is where the tone rings are mounted...
I bought a 5.7 ECM and harness from Modern Muscle. a stand alone TCM from Paramount Performance,and a complete harness for the entire car from Haywire.
The circuit board behind the instrument panel has all the circuitry for the body controls...heater, a/c etc.
We had to hack into the original harness so much we decided to rewire the entire car.
The transmission (NAG1) will NOT work in this set up unless you do the stand alone TCM. This was further compounded by the fact there was a split in the partnership at Paramount Performanceand the guy who was the NAG expert split. I finally got his # from Paramount and he has reprogrammed the TCM. I just got that back last week so I cannot even say it works yet.
Not trying to flame LXModguy ,but this is the TCM I got through him.
The truck set up works for some reason I cannot explain. I have seen it set up in cars that work but I could never get all the details from the guys with those cars as to what it took. TONS of manual transmission/3 gen Hemi swaps and that works on a whole different level of computer programming that I cannot explain.
I only know I am where I am with this thing and it has cost me a **** ton of $$$$$ because nobody has a simple swap solution to this concept.
If you can engineer the speed sensor swap or just bring the entire rear axle over it might work out. i CAN tell you there was no way to get the speed sensors mounted on the axle in my 8 3/4 rear assembly. The only reason I did not bring the rear from the donor is because it was a re-engineering issue and hacking into the package tray would have been required.
Proceed with caution and a HUGE bank account!
1.
