use2teech
Not sure if someone can offer any info other than what I've read in older posts. Have a 65 coronet 500 and the speedo needle bounces all over when driving, sometimes 10 mph jumps, sometimes 20 or 30. Does it all the time. I had an Imperial Services cable, bought it new when I built the car and it did it. I took the cluster out, cleaned everything and it still did it. Bought a used cluster from a member and it did the exact same thing, no change whatsoever. I ended up melting my cable this summer and bought a really nice cable from Kramer. Installed it and it's exactly the same. I've lubed both the old and the new cables, tried a light amount of a synthetic trans lube then a heavier amount of general purpose grease. Seems like I must be missing something as no matter what I've tried, nothing seems to make any change at all. It seems exactly the same each time.
