egrand1508
- 11:48 PM
- Jul 21, 2011
- Illinois, Metro-East
I can't find again where I read this, but I think in the limp mode (or as Chrysler called it "Limp-in" mode) the computer will just give around 10 degrees or so of advance and leave it there at all engine speeds. The Lean Burn distributors don't have any weights for centrifugal advance. 10 or so degrees is fine to start and idle, but is way to little for driving around, which causes bad performance.
I just found out that MyMopar.com has been putting the old Service Tech films on Youtube and here is a link to one on Lean Burn: http://youtu.be/So21Dn7jpWU If you watch this you'll see why most people give up on it.
If you do replace the Lean Burn, you might have to replace the carb too. The new distributor needs a vacuum port on the carb, and the Lean Burn carbs eliminated that port.
Good Luck!
Good Luck!
