68sportsatelliteragtop
I just got the Satellite back from the front end shop after getting an alignment. I had set it up after rebuilding everything good enough to drive it there about 15 miles away.The steering wheel won't return by itself after a turn. Other than that the car handles as expected. I have read somewhere about the car not centering up due to improper alignment, but it handles well otherwise. The steering box is a rebuilt box I got from Summit with stock specs.The 68 box was on backorder everywhere due to lack of cores, so I got a 73 and up box and pitman arm. Measured it every way I could think of and didn't see any difference other than shaft diameter. The steering column was R&R and looks properly aligned.I looked in the factory service manual and don't see any of the listed possible causes present, Any ideas guys?
