idrivemopar
Just wondering what everyone with headers is using for their collector bolts that do not come loose? It does not appear that double nut helps, and most supplied nut, bolt and lock washer setups suffer from heat expansion that cause them to come loose. Not a fan of tack welding the nut in place either.
I have seen two recommendations, using Stover lock nuts on grade 8 bolts or getting a Stage 8 collector bolt set?
What have you had success with?
