corunna bird
warranty for 90 days which has passed.
I will give the vacuum a try.
exhaust was all tapedal up.
dont spray carb cleaner your going to wipe the walls down. Take the oil pan off and inspect the rotating assembly and see if anything foreign is stuck in the cam valley..
Just thinkin' out loud on this one...
What was/is the advertised compression ratio? Doing a compression check by hand...no...especially with the little said oil in the bores. Reading won't be accurate.
Way I have learned, engine needs to be turned over by the starter, carb wide open, plugs out (at least one per hole). Three hits at the gauge, reading the third hit.
Your right thinking it could be something with the valve opening timing. ?? But, you also said it had been test run, right?
Whatever you do, keep in mind if it's actually hydraulicing (kinda doubt it, since your not dealing with that much oil), a rod could actually get bent.
was the cam degreed in ? my first street hemi had 205 to 209 lbs per cyl when stock. it was hard to turn over by hand. when I put a bigger cam in it, the cyl pressure dropped, and it was almost impossible to turn over by hand w/o waiting on the pressure to bleed down . go figure cratye it up and send it to me , I`ll make good use of it ! LOL "just a note" my 505" wedge is almost impossible to turn over by hand too.Right. Gotta admit, I'm one of those who can only 'wish' I could get my hands on a Hemi.
But, heck, it's still only parts and pieces! Even on a motor like that one. Turns over good, with plugs out, right...even on my not run yet 440, plugs in, real hard to turn over by hand. That's at 10-1.
'Crate' motor...no telling. Why I build my own. Few things I would be sure of, before firing it off, would all be in the valve timing/opening, to be positive it's okay. Should know on the cam type, lifter type, valve to guide clearances, and valve lash, too.
Don't know the complete picture, so might be worth a look-see. 'Could' be all okay.
Best of luck on it!
I have been kind of watching this, and then it hit me. If I am not mistaken, this is a stroker hemi, and it requires a stroker cam (shorter base) for clearance with the crank IIRC. I had a customer call me about the same thing, and when I had him check the cam, they had sold him a regular cam, and it was hitting. Once he replaced it with a stroker cam, no problems. I am curious if maybe they built the short block, then put the wrong cam in it??
You are correct, he did say that.The OP stated that this motor has been run already and dyno'd so it supposedly works fine.
From the Eagle website:69Bee the taller block cam bore is needed for this. Ive never seen these types of cams your talkin about..
