- 8:13 AM
- Jan 23, 2009
- New Jersey The State of Tax Theives
Mopower have you tried the seal kit from Mancini or World Castings for the leaking?
You are in China? I thought you lived in Southeast CA.I'm using the 440 Source Aluminum Heads on the 67 GTX I purchased from 67 Satellite
I went through the entire engine with my "Bud"
PS: 440 Source is 42 miles from my house
I recall reading that. Hope you got it sorted out! Thanks for postingI can tell you first hand if you go Eagle pay attention to the rear main seal knurl on the crank.had a 4.15 stroker .The knurl on the crank was cut to deep and oil gets underneath the seal and leaks. seams I'm not the only one that has had this problem.
Ski...If you are living in the High Desert in Reno then you are correct. They moved a while back to Carson City NV to get out of doing business in Commiefornia. Here's the address...cr8crshr/Tuck
440 Source
3680 Research Way
Carson City, NV 89706
Hi, still leaking when I pulled the trans back its bone dry!?. nothing obviousI recall reading that. Hope you got it sorted out! Thanks for posting
so what to do (1)try another seal, retainers ... (2) pull the motor rip apart a strong running motor and fix it propper. funny it didn't leak on the dyno or maybe we just overlooked it.
