Mike Gaines
- 4:54 PM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
I have been racing only using my footbrake (I do not have a transbrake). I apply the footbrake on the start line and bring the RPM up to 3000 just riding against the converter (5000 flash). The brakes will hold it at 3000 RPM.....and everything is fine with this technique (when I release the footbrake and floor the gas it LAUNCHES HARD,,,not stumble, no miss, no farts,,,,it just kicks butt and goes)....BUT....I do have a 2-Step Box attached to my MSD Ignition with an adjustable low end chip that I have set at 3000 RPM (just like the guys have who use it with a transbrake)....I have a toggle switch where I can activate the low end rev limiter on the 2-step which is activated off my footbrake brake light switch....and I want to be able to use this method to launch the car...activating the 2-step rev limiter by depressing the brake pedal, flooring the accelerator pedal and then the motor comes up to 3000 rpm when it starts dropping cylinders to limit the rpm to 3000....everything is fine up until this point.....but....when I release the foot brake to launch the car I get a fraction of a second "stumble", NOT a clean start. I am sure it is in the carb adjustment somewhere but I do not know where to start. It is a brand new Dominator 1050 that works perfect using the footbrake launch without the 2-step and works perfect going down the track (10.582 @ 126.33) but I need to get rid of the stumble when launching off the 2-step box...SUGGESTIONS PLEASE
