miller
I'm wanting to put SS Springs on my 1962 Plymouth Sport Fury 413 and I know different front hangers are required. My front hangers were welded in conjunction with some frame boxing/ stiffening. Where can I get the needed dimensions for cutting and re-welding the front hangers for the SS Springs?
Thanks,
al_wildman
Hmmm. Just reread this post. Which car are you mounting the springs on..this one, or the coronet...or both?
Either one the front hangers are usually bolted on. If you can locate the original bolt holes, and a stock hanger, you should be able to measure things.
Wheel/tire size, rear axle, and anything else that affects how the car sets will influance where your springs need to mount up. Mine is all just stock...per say.
