The car is braked…. I need your help please
Shut
11:50 PM
Madrid
Hello to all
When it moves forward it moves but when it moves backwards it stops. In reverse the car stops, But if I accelerate it moves a little
The parking brake it’s fine and the differential it’s fine (I bolted off the transmission and the rear axle go fine)
The parking brake its released
Thanks in advance
Check the rear brake shoes. I had a piece break off and would jam between the drum and shoe.
Weird but only in reverse. Maybe ?
Recent brake work? Are the primary shoes in the proper position (shorter shoe faces front).
what I can understand is that he said he bolted the transmission so maybe unbolted driveshaft? He did say axle goes fine so maybe reverse is slipping? band adjustment? if he tried to accelerate and it moves a little.
Tell us a little more about your car. Milage, transmission model, is this a new development- has the car been operating OK before this started?
Mike
Thanks to all
Well I need to check the transmission fluid
69 Charger 383 with 500hp. Summit TCI 727 STREET FIGHTER. Diff 3.53
No recent work on brakes
Yes I bolted off the trans to discard the rear brakes or diff issues
I have 2 videos, apologies are in Spanish but you can see the rear brakes and the trans bolted off to discard
No in neutral the car dont move
The last owner dont know about this issues, then I think that the car go fine before…
Yes if I try to accelerate it moves a little…
How long have you had the car? Looks like problem is in the differential.
This could be the transmission.
One example: I recently read the line pressure, the internal hydraulic pressure, is greater for operating in reverse, than it is moving forward.
You could have low transmission fluid levels, a poorly adjusted throttle pressure linkage, or a worn out transmission.
If you know the transmission to be in good order, and the throttle pressure linkage is adjusted correctly, then I'm stumped. The drive shaft, u-joints, and differential would normally operate equally the same moving forward as it does backward.
The only thing left is test is the transmission.
How can I test the transmission??
If I remember correctly it's hard to turn the drive shaft backwards by hand on a 727.
Place the transmission in neutral for a few minutes then shift to reverse and see how it acts.
Like stated check fluid level. If it's okay then check band adjustment and pressure test.
Good luck!
Are you sure the emergency brake cables are not sticking??
