ThermoQuad Secondaries Not Opening All The Way
Dibbons
5:13 PM
La Paz, B.C.S., Mexico
Getting ready to rebuild the 6139S ThermoQuad I plan to use on the '72 Satellite Sebring Plus 340/305 project (see thread: "Project Odyssey"). Well, took the carb out of the box it was shipped in and first thing I did was open the throttle. I found the secondaries would only open part way. Oh no!
After some looking around, I found some kind of wasp mud nest had been built into one of the secondary throttle bores. It was no problem to knock it out with a simple screwdriver. (I will be following the article on FABO that RustyRatRod posted on how to rebuild a ThermoQuad).
Mine are always only open 86 to 88 degree as
I have found that best for performance.
I believe why it might be is air flow over
Secondary emulsion tube is disturbed over
that amount which hurts power.
My .02 = For free!
Go ahead everyone feel free call me an idiot again.
My .02 = For free!
John, it might also be for better distribution to front barrels, those’d being much smaller and secondary more to the back of intake. I wonder how the TQ would work if it was turned around backward?
That's the correct factory opening as manufactured. My problem as you can see was the wasp nest was only permitting the secondary system to open half-way.
There also looks like mud in the front air vent. The MP bulletins recommended [ for WOT ] the sec blades at 88* for a single plane intake & 81* for a dual plane. It is not always about total airflow, but distribution also...
Congrats on using a great carb.
My .02 = For free!
The factory 's attempt to limit air flow to a maximum as determined by the vehicle manufacturer to be able to use one basic carb design on several different engines. GM's QUADRAJET did the same time be used in different engines...like the PONTIAC's OHC 6. Usually fixable by bending the secondary stop bracket to allow for full open secondary throttle plates although the gain in air flow is a negligible increase.......
BOB RENTON
When I open the secondaries to 90 degrees,
even with changing the jets and Air Door openings
numerous times I lost significant observable HP.
However, of course I do not expect anyone to believe me.
John,
I believe you. It is not always about total airflow, as many think....
My very close friend George Thomson(RIP) owned Carburetor
Flow Engineering in So Cal. He had a wet flow bench as well as
a dyno. We did extensive research on the Thermoquads (mostly
him while I just watched.
When the Air Door was opened to far it disrupted the flow and
atomization out of the secondary emulsion tubes. Changing the
holes in size or location only seemed to aggravate the situation.
Of Course, very few on this forum will ever believe me about anything,
I take the time to explain of my 60 years of experience!
Without going back up the posts what angle did y’all come up with? Should come in handy on my stocker
The MP bulletins cover this for the SB engines. Sec open to 88* for a single plane, 81* for a dual plane. Air Valve position is also critical. Recently saw a 25hp loss on a 440 when the AV was opened a further 0.100". Because of the huge size of the sec blades....& air valve.....they will have a noticeable impact on distribution...as well as total airflow.
