Thanks for the tip. But how do we know for sure? I know AI makes mistakes but disconcerting when conflicts with human knowledgeThe 1004 is the correct gasket.
I plugged the P/B hose and it made no difference in the idle speed. Removing carb now.I forgot to mention above that I thought I noticed a slight decrease in idle speed when I stepped on the brake pedal. I will have to plug that booster hose later to determine if that is a factor in leaning out the idle mixture (the hose connects to the rear of the intake manifold, not a carb port).
I did have puddles under the fuel wells. However, I turned the carb upside down a few times to drain the gasoline still inside by way of the three air vent tubes that stick out of the top of the carb before I took the three main body pieces apart.2 the fuel wells need tk be glued with a new glue, I use loctite marine, but there are others that are ethonal, heat and fuel resistant.
If those are leaking when you take it apart there will be a puddle under the fuel well
