Demonic
That sounds like heat soak to the coil OR maybe the Orange Box. Where is the Box mounted?After sitting for 20 minutes went to put it in the garage. Ran for 15 seconds then just died before I put it in gear.
NO SPARK!!!
NO SPARK!!!
Mopar single points distributors.Were your distributors originally mopar electronic or points?
I have been useing the same pertronix conversion for over 10 years.That is the way I'm LEANING,!!
I did something very similar to my '74 SE 400 a few years ago and it has worked flawlessly from day one! I was advised to pair the GM module with an "E" Core coil and the result was the hottest spark I've ever seen. I opted for this one... Speedmaster Ignition Coils PCE382.1030.
I know the OP does not have an original MOPAR distributor and believe that is required for using the CNC fabricated adapter plate offered by one of our members; allowing the GM module to attach underneath the distributor head. I purchased a distributor from Rock Auto cheaper than I could find a OEM unit and had to drill and tap the required mounting holes-no big deal. I wish I could recall their name. Did you read my #17 post? Hopefully they will speak up. Don't see why mounting it like in the video would not work. Looks a little rough but "function before form" ya know.....
Mike.
Agreed butttttt, If you read the Mopar factory literature that cover the chrome box it states that they are designed for high RPM usage & shouldn't be used for extended idle periods or the module can overheat and fail.....As 68 Sport said above the Mopar chrome boxes seem to work better than the orange ones.
I almost did this around 10 years ago when I first got my car, but had read that an HEI conversion is also not necessarily bulletproof. Any watch outs to be aware of for reliability on HEI?Haven't read the posts. Dump the Chrys box & use a $30 GM HEI pin module with your Chrys dist. Wiring diagrams on the net. If you want to splash out a few more $$$ on an E core coil, you can ditch the bal res, another failure point gone. Run 0.060" plug gaps.
