Time for a new radiator, which one?????
Dajkzo
9:21 AM
Center of Massachusetts
Hey folks,
In my 70 RR I currently have a 26" three core. With the new engine building 500 hp and the old radiator looking a little tired the time has come to replace it. The default would be an OEM replacement that is a 4 core. What about a Tri-flow, is it worth the price?
Anyone want to offer up suggestions ?
Someone should make pop-corn LOL
I have used 4 Griffin direct replacement style radiators, little satin black and unless you look for #'s you don't know the difference.
The originals work well but are heavy. They actually are not all copper but a mix of brass and copper. New aluminum radiators are more efficient and weigh less at the same time. THe only drawback I see is that they don't look exactly like the stock versions.
I have a 26" unit from ECP. I got advice on this site about them. Approx $260 shipped to me. It has factory style mounts and provisions for the shroud.
I'd regret spending over a thousand dollars for a radiator when you can have similar performance for 25% of that.
Here is another aftermarket one that I used in a customers car that is performing great. Car had A/C and was a stock 383. His original radiator did OK until he used the A/C.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/301546384651
As stated in a previous post, when using aftermarket I prefer Griffin, but this guy didn't want to pay the price. Also a recore of your original is the best option if you are wanting to keep everything as original.
I have a $200 Afco aluminum triple flow that we tigged 4 aluminum "L" brackets to. For cooling it's a $135 Spal multispeed fan as a pusher as there is NO room for anything on the engine side.In the heat last week it stayed below 185*. At the track I go into the waterbox at 150/160* and cross the stripe at 180*. No shroud and hoodless.:blah::blah::blah:
5.30.17 010.jpg 8.25.17 008.jpg 8.26.17 009.jpg 8.26.17 011.jpg 8.26.17 012.jpg 10.15.17 002.jpg
Got mine set to a 4 core $600. No "hot" HEMI anymore. And copper /brass dissipates heat better. Aluminum is just cheaper....
Rick Ehrenberg would disagree with you on heat dissipation.
autocity1958 have factory looking aluminum radiators in black 22 or 26 inch they are on ebay.
Cant go wrong with Glen-Ray for quality, originality, and a company that stands behind their product!
That is the exact radiator I bought. You can get them black or unfinished. It is spot on for the original and mounts up to original holes in support. I believe my shroud bolted right to it without modifying. I love mine, no issues.
