Ok,
New radiator is installed and testing is complete. First, no leaks!!! No mishaps!!
I started with the new radiator and the current 180º thermostat. Before the engine ran 190º with air temps in the high 80s-90s. Sitting in week-end traffic it would climb to 210º and even with a 40mph cruise the temp would never get back to 190.
Post install it would run 185º and I was sitting for maybe 10minutes and it never climbed above 190. Once I was moving at 2000-2500rpm(40-50) the temp dropped down to 185. The other change is an 18" Derale flex fan with a 1.5" spacer.
Test number 2 was the addition of a 160º Milodon thermostat. The temp stayed at 170 and I did my best to wail on the engine.(5800 in 1st and 2nd along with some hard driving on a quiet country highway) The temp never moved, so when I got home I let it idle for 20 minutes. Never got above 175.
I have my reasons for running a 160. It all depends on what alloy your pistons are made from, clearances, and how much power you build.
My oil temp is steady at 210º with a thermostat/cooler config.
Overall, I'm very pleased with ColdCase. The fit is excellent with a Mopar brand shroud, it was a simple plug n play. The Derale fan is set to the correct depth in the shroud and it pulls plenty of air at idle/low speed.
Sorry about the lousy pictures, my IPhone got dropped.
