To tub or not to tub
roadrunner69440
12:43 PM
Pa
Ok I just being a little lazy right now, car in the garage, I'm in the house. Was pondering mini tubs on my 69 rr. I know the minis would alow 2 more inches of tire but the question at hand would be what clearance issue would I have with the springs then. I got both frame rails replaced(new) and cringe when I think of cutting them up. How about some thoughts , info, and some advise, thanks, you guys are the best!!
Depends on your plans for that car. Non # matching and you plan to drive the crap out of it - do it. If it's your second wife and you never park it closer than 50 yards from anyone else - don't to it. :)
And secondly: Do you NEED it?
I say do it. Own it, drive it like you want to. I think it would look really nice mini tubbed.
Before you decide, check out uscartool.com for info on rear spring relocation kits. I would tub it, but that maybe because I already have, and like it.
I wouldn't do it....
I did. Both inner and outer. It's a big commitment. I got 3" with the inner and 2-1/2 with the outer and a much more squared off tub. It measures 17" wide now. The leafs will be in the way with the inboard mini tub, so unless you're going to also do a leaf spring relocation, it's probably NOT worth it. My other car runs 295/50/15's and 275/60/15 drag radials in stock tubs. You can run a big tire without it, unless you want to lower the car. I put lots of pictures on this site.
i thought everyone NEEDS bigger tires lol
That's the info I was kinda lookin for, someone who has done it and do t seem to regret it. My car is not #s matching and I DO plan on runnin it the way it was intended however it will also be a show car or a super nice driver. I want my cake and eat it too .
hey hemi, thanks for the info, what other cars do you have and can you send me a link to them, thanks again for your help!
Here it is with the 295/50/15 setup on it. Stock wheel wells, Cal-trac mono leafs and strange double adjustable shocks. Leafs are NOT relocated on this car. The other setup is 275 drag radials on some centerline wheels. Same car.
wow, sweet rides , I envy you! good info and pics, think I'll leave it alone , maybe if I ever do the 70 setting here ,I'll do something like youre superbird and get crazy with it.
