furyus
- 3:23 AM
- Jan 5, 2010
- weeki wachee, florida
There should be a ton of info on this. I keep posting this, so, one more time.hey guys. I'm trying to remove my torsion bars and then my entire k frame.
Question.....the bolt that determines ride height, does it come all of the way out? I have turned and turned counterclockwise, but it's very difficult, even with a pry bar
First, get the car safely on jackstands. Remove the torsion bar adjusting bolts. Remove the torsion bar clips on the rear of the torsion bar at the trans crossmember. Remove the upper control arm bumper from the frame. If you don't do this, it will keep some tension on the bars, and will be hard to remove. Unbolt the strut rods. Remove the nut holding the lower control arm to the K member. Using a pry bar, and place the pry bar between the K member, and the lower control arm. Pry the lower control arm to the rear of the car. This will push the torsion bar out through the rear crossmember. Lastly, do a search for your cars service manual, or the closest you can find on this site.
